we have change the faulty CPU Board (X-board 450-GC programmed) of Varian GC-450 with new ones & after configuring the setup with old parameters we are facing a problem, when we load the method a message appear
"start Direct Device Download: System configuration is no valid(or communication problem)"
system log message= Method conflict with setup, method adjusted!
we are using the Galaxie software with Fixed IP
local authorized Varian/Bruker try his best but cant solve the problem.
please Help
