Locking method templates in chemstation
Posted: Tue Aug 20, 2013 7:21 am
by eriks1962
Hi there,
I am using Chemstation as HPLC data aquisition software (not chemstation plus) and I was wondering whether it is possible to lock files to prevent alterations in for instance method templates? Or must this be done in the windows right settings?
Thanks in advance,
Erik
Re: Locking method templates in chemstation
Posted: Tue Aug 20, 2013 4:17 pm
by nimbi63
What revision ChemStation are you using. (Help > About) will give the revision with the build number in [square brackets].
Posted: Wed Aug 21, 2013 9:22 am
by eriks1962
I'm using Rev. B.04.02 [96]
Posted: Wed Aug 21, 2013 12:57 pm
by nimbi63
About all you can do in that revision is to set Operator or Manager level. View menu > Change Access Level. You can set a password to get to Manager level.
