Locking method templates in chemstation
Hi there,
I am using Chemstation as HPLC data aquisition software (not chemstation plus) and I was wondering whether it is possible to lock files to prevent alterations in for instance method templates? Or must this be done in the windows right settings?
Thanks in advance,
Erik
What revision ChemStation are you using. (Help > About) will give the revision with the build number in [square brackets].
I'm using Rev. B.04.02 [96]
About all you can do in that revision is to set Operator or Manager level. View menu > Change Access Level. You can set a password to get to Manager level.
In total there are 39 users online :: 0 registered, 0 hidden and 39 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 39 guests
