I am running an Agilent AS80 connected to an Agilent 7890. The AS80 is used as a headspace sampler. Both instruments are being controlled through Empower. I would like to use the 2 vial overlap cycle for the headspace but the system will only run the first injection and then stops right when it should sample the second vial. I believe the computer is losing it's connection with the instrument. Anyone working with a set up like this? Any help would be appreciated.
