Chiral AGP and Chiral HSA column evaluation
Posted: Tue Jun 25, 2013 5:35 am
by hoangduc
I need to evalute chiral AGP and chiral HSA column, but i don't know procedure testing. So i need some procedures testing and acceptance value for reference. Can you help me?
Re: Chiral AGP and Chiral HSA column evaluation
Posted: Tue Jun 25, 2013 2:28 pm
by tom jupille
If you will be using a column for a specific method, the best way is to run a "mini system suitability" for that method. You don't have to run replicates, but just a single check sample to verify that retention, plates, tailing, etc. are OK.
If you are getting the columns for "general purpose" use, the best way is to re-run the manufacturer's test.
