I bought a used LC/MS system with HTC as an autoinjector.
If run LC/MS with Chemstation (Revision A.10.02), it could start and stop according to run time setting.
If run LC with HTC and composer softeware (Revision 1.5 , PAL Firmware >2.2.0), it could start and stop the run according to run time setting.
But, if run LC/MS with HTC and Chemstation/composer software, it could start run for both LC and MS, the LC could stop run according to run time setting, while MS couldn't, it kept running without stopping.
Is any one familiar this symptom and can help?
gyy54
