Does anyone know what is the minimum version of Chemstation (not MS Chemstation) that is required to control a 7890 ? B.03 is currently in use but we're looking to drop back to B.02.
Rich
[EDIT]
Found the answer in the link below, B.03 is required.
www.chem-agilent.com/pdf/ChemStation_B.03.01.pdf
if you're slave to the grind"
