I have some problem with CP-TAP column.
Earlier i used this column for triglycerides analysis. I cann't say that its "behaviour" was perfect, but now resolution of peaks become much more worse. A week ago i took it off to made FID calibration with standard solution on another column. After this I put CP-TAP column on, but peaks resolution on chromatogram (in the same conditions) become worse. CP-TAP was blown for two days with carrier gas (H2).
May be some one have an idea what to do?
