Tips on getting ES-MS detector response for small molecules?
Posted: Mon Jan 28, 2013 9:21 pm
by Incitor
I have an LC-MS in ESI mode. The problem I'm having is that I'm not getting a response from the MS detector for most analytes. The mass range for my analytes (the known ones anyway) is 144-154. I'm seeing peaks on the DAD but only noise on the MS. Any thoughts? Do I have to switch to CI?
I have an agilent 1100 HPLC with G1946D single quad in ESI and I'm running reverse phase separation with water/acetonitrile and a C18 column.
Re: Tips on getting ES-MS detector response for small molecu
Posted: Tue Jan 29, 2013 10:21 pm
by tom jupille
I'm no mass spectrometrist, but (in very general terms) ESI ionization essentially occurs in solution (inside the solvent droplets), so it's probably a good idea to have *some* buffer in the mobile phase. Also, not all molecules are sufficiently acidic/basic to ionize under ESI conditions, in which case APCI may be required.
Posted: Tue Jan 29, 2013 11:02 pm
by Incitor
Thanks for the tip. Yeah, I've thought about that, I will give it a try and see if that works. If not, I'm going to have to switch to APCI.
Posted: Wed Jan 30, 2013 2:32 pm
by lmh
what are the analytes? Not everything ionises well in ESI. Also remember that if they're very small and volatile, they will dry off just like the solvent does...
Posted: Wed Jan 30, 2013 7:40 pm
by Incitor
My analytes are not that volatile. They remain after a rotovap.
Actually, I added 0.1% v/v acetic acid and it really improved the signal from the MS. I'm going to try formic acid next to see if it does any better.
