Particle surface coverage of LC column
Could anyone give some insight on how to determine the surface coverage of the particles, either by experiment or by calculation? Thanks.
- tom jupille
- Site Admin
You need to know the surface area (usually determined by porosimetry) and the percentage carbon (standard CHN analysis).
Convert the carbon percentage to moles (use the appropriate molecular weight for your ligand) and divide by the surface area.
Thanks. That helps a lot. Is the CHN analysis the same method the column manufactures use to determine the carbon load?
- tom jupille
- Site Admin
Pretty much (actually, only the "C" part). Basically, burning off the organic part and measuring the resulting CO2.
In total there are 40 users online :: 1 registered, 0 hidden and 39 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 39 guests
