Exporting number of injections from Empower3
Hi!
Do anyone know if it's possible to extract and export information about the total number of injections made using Empower3?
I only need the raw data and then I fix it in excel.
For example, in a project(Empower3) I can see all injections made, what method was used and on which system it was carried out. If I could get my hand on that info (i.e. using Excel) I could create a VBA macro to visualize the time spent on analyzing certain samples.
Write a report method to do that, then name said method in on the Reports tab in an export method that will create an ascii file and send it to the destination of your choosing when you "Export" a Results Set. The resulting .ars file can be read directly into Excel.
Are u aware of global projects in Empower.Interestingly,what are you planning to do with this data?
