doubt regarding Carbendezim and benomyl
Posted: Wed Oct 10, 2012 10:41 am
by Davidantony
I am testing pestcides in Rice according to COMMISSION REGULATION (EU) No 893/2010.In this there is a combined MRL for Carbedezim and benomyl since benomyl has low stability and is hydrolysed to carbendezim easily.I have doubt that is benomyl & Carbendezim included in the mix standard or i run carbendezim only.
Re: doubt regarding Carbendezim and benomyl
Posted: Tue Oct 16, 2012 4:55 am
by mckrause
You run carbendazim only. There are special prep methods that you can use to keep from hydrolyzing the benomyl, but under the standard EU/FDA prep procedures you will only get the peak for MBC.
Posted: Thu Oct 18, 2012 4:40 am
by Davidantony
Thanks for your valuble infomation
