High air and water peaks on Varian 2000 GC/MS
Posted: Wed Sep 26, 2012 3:24 pm
by Adamcon8
I was just wondering if anyone has had trouble with high air and water peaks with the Varian 2000 GC/MS? Would anyone know the source of the problem? What was your plan of attack in correcting this? Any info would be great. Thank you.
Re: High air and water peaks on Varian 2000 GC/MS
Posted: Thu Sep 27, 2012 3:47 pm
by Hornet
Check the injector end of the column, the injector oring, gas filter and the transferline end of column if you have small/medium leak, change the septum too.
If you have a large leak you would have already broken your filament i guess, and probably your turbo isn't even at full speed.
Davide
