Problem with the Integration Events Table
Posted: Thu Jun 21, 2012 9:17 am
Hi everybody,
I am using an Integration Events table with Chemstation to integrate the peaks. What I do not understand is why the peaks are not integrated using the inegration times I set in the table and they result slightly shifted.
Many thanks for you help.
