Problem with the Integration Events Table
Hi everybody,
I am using an Integration Events table with Chemstation to integrate the peaks. What I do not understand is why the peaks are not integrated using the inegration times I set in the table and they result slightly shifted.
Many thanks for you help.
Most integrator events are not turned on or off at the times specified in the table, they are made available at those times. The changes in baseline associated with the start or end of a peak are required to activate the integration algorithhms modified by the integration events.
It's sort of like you putting fuel in a tank, you still need a key to start the car...
PS - I deleted the copy of this found in the GC forum, this is more of a data question.
