I have a question for Chromeleon 7.1 users. Does anyone know if it is possible to assign multiple names for one peak (manually)? I have two unseparated peaks (occuring as one) that need an assigning. Somehow it worked when assignment was done by processing method and when I assigned a name later manually, the earlier name retained with the manually assigned name for the same peak. However as this is needed for method development I don't have time to create (modify) new processing methods for each condition, assigning peaks manually is a way faster...
