Lipid Area Reproducibility
Posted: Thu Feb 16, 2012 3:52 pm
I am analyzing a mixture of three lipids by HPLC with ELSD detection. I get good separation on a C-18 column but the %RSD for one of the components is large (~15%) but the other two lipids show good reproduciblity (%RSD < 2%). This component is a PEGylated lipid and is the second peak to elute.
The problem is not carryover from a previous injection because injecting a blank after the sample results in no peaks in the blank injection.
Is this a problem inherent to using ELSD detection with PEGylated compounds?
