Internal Stds
Posted: Wed Feb 15, 2012 9:39 pm
by itsbourne
We are trying for make naphthalene solution of 20ppm in DCM. When we analyse it in GCMS the conc. shown is 30% less around (14ppm).
This is consistent with several other solutions prepared with different solvents. Is this due to problem with GCMS?
Can it be fixed using internal stds?
Jason
Re: Internal Stds
Posted: Thu Feb 16, 2012 1:25 am
by Consumer Products Guy
I'd use a solvent less volatile than DCM.
or use HPLC
Re: Internal Stds
Posted: Thu Feb 16, 2012 7:01 am
by Peter Apps
Jason
How do you know that the concentration is "14 ppm" ?
Please do us all and yourself a favour and use proper units - the density of DCM is 1.3 g/ml, so if you are mixing up volumes and masses in calculating your "ppm" the problem disappears.
