What is baseline resolution?
In chromatography, what does "baseline" resolution mean?
In principle, it's just what it sounds like: the amount of resolution between adjacent peaks at which the signals will drop to the baseline.
In practice, many textbooks will state this value as Rs = 1.5 . This is a bit misleading; it is the resolution at which two equal-sized Gaussian peaks will have less than 1% overlap. Decades ago, this used to be called "99% baseline resolution" (for obvious reasons); over the intervening years, the "99%" part got dropped off and it's just called "baseline resolution".
And, of course, you know that resolution (Rs) is the ratio of center-to-center separation to average baseline width for two adjacent peaks.
Ah right, so its the resolution when the two peaks are fully separated. Thanks.
In total there are 49 users online :: 0 registered, 0 hidden and 49 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 49 guests
