I have write a macro to export data result file to a specified folder.
the macro works well, it will copy the report.txt & report.pdf file to my pre-set folder once user quantified complete and print out these two files in current data file folder.
It works well before,but when i re-installed the Chemstation last few days, when i click "print" to generate report.txt &report.pdf files, the report.txt was generated, while there always pop up a window to ask me to choose a folder to save pdf report.
it should be named with report.pdf and saved in the current data file folder.
i have create a clear OS and install the chemstation again, but it still pop up.
Is anyone got this problem before?
My chemstation version is Rev.B.04.01 , with novaPDF pro server V5 (provide and installed in installation CD)
Thanks .
Tod
