peak alignment and quantification software
Hello. Are there any freely-available programs that compare LC-MS runs (high resolution (100,000)) in full scan mode without regard to the analyte(s) of interest?
Essentially, we would like to use this approach for several of the various "-omic" approaches as a way to identify differentially-expressed molecules in a complex mixture, and go back later for targeted MSn characterization from a specified mass list rather than performing quantification via a BIG5 or some other DDA approach.
Any thoughts would be appreciated. Thanks.
XCMS can perform peak detection, integration, re-alignment, etc. as well as a little bit of multivariate analysis. There is an online version that is very user-friendly. Worth a try.
https://xcmsonline.scripps.edu/
The "real" software version works under R environment.
and R is free and fairly easy to set up, and you don't need to know much about R in order to run xcms.
If you do decide to install R, it will also handle PCA for you (and if you're feeling clever it can do PLS too).
In total there are 49 users online :: 1 registered, 0 hidden and 48 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 48 guests
