Column head pressure determination
Respected,
For GC, I need help in determining column head pressure at specific temp. From Van Deemter plot, I have determined the optimum linear flow rate. We are give parameters - column length, internal diameter & stationary phase thickness.
I searched enough.. all I found was that column head pressure depends on all these parameters, but how? wiki suggests using Poiseuille's equation, however we dont have inlet / outlet pressure readings.
Any help would be greatly appreciated. Thanks!
Anyone? Please..
Inlet pressure = the "head pressure" (is this what you are trying to estimate?)
outlet pressure = 1 atm
The math (which you have already found) is here:
http://en.wikipedia.org/wiki/Poiseuille ... ble_fluids
You know the flow rate, the capillary diameter and length, and the outlet pressure. The only parameter you are missing is the viscosity of the carrier gas at your operating temperature.
In total there are 25 users online :: 0 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 25 guests
