Empower 2: Ring Buffer Overflow
Posted: Fri Nov 04, 2011 12:10 pm
by EmpowerGuru
We have an agilent 1100 with an RI detector that keeps getting this message around the second injection of a sequence. Anybody scene this one before?
Re: Empower 2: Ring Buffer Overflow
Posted: Fri Nov 04, 2011 7:23 pm
by DR
I've seen it with A1100s before - it doesn't seem to interfere with anything, has caused me no problems. I'm not sure waht causes it.
Posted: Sat Nov 05, 2011 8:37 am
by EmpowerGuru
It causes our instruments to shutdown when we get it
Posted: Mon Nov 07, 2011 2:42 pm
by DR
You've checked the A1100s for local errors, table sizes of projects etc.?
-How much RAM in the LAC/E?
-Does anything show up in the event logs on the LAC/E at the time(s) that the buffer errors show up?
-Is A1100 hooked up via Equinox card or Ethernet?
-If Ethernet, what is typical sampling rate and wave range for DAD runs?
-How many instruments are on this LAC/E?
-Has Waters been able to help at all (have you searched their www site for the error)?
