Integrating different wavelength under EZChrom Elite
Posted: Fri Oct 07, 2011 1:35 am
Hi there, another question about EZChrom Elite.
First of all, this is for an 'offline only' license. In other words, with this license we can't do modifications to the method itself, and there maybe some fine details that's different.
Ok, my problem is, we're running a certain sample that has different compounds being more sensitive under different wavelengths (Diode Array detector). When we then want to analysis the data in offline, we can only modify the integration event and defining peaks with the first wavelength channel we've set in the method.
Say, in the method we've set 215nm and 290nm as channel A and B. We can later open the data file and see the chromatogram of both wavelengths on another computer with offline only license no problem, but we can only integrate/calibrate with channel A (215nm) but not the other one.
Is there maybe something we've missed? Maybe in the configuration of the instrument, or just some hidden tricks we've not noticed?
Thanks for anyone who might help us.
hat
hat
