SPME fibre stuck in septum issue
Posted: Wed Oct 05, 2011 12:26 pm
Hi, has anyone come across the issue of getting Supelco SPME fibres stuck in headspace vial septa? We are using a CTC-PAL setup on a Varian GC and found that fibres have been caught in the septa, presumably as the protective needle is withdrawing from the sample vial.
Does anyone have any suggestions as to how we could check for needle penetration given that this normally happens in the heater shaker so isn't visible?
Could it be that we've just purchased a faulty batch of 100micron PDMS fibre assemblies?
Any advice would be gratefully received, many thanks in advance,
Sally
Sally
