R code manual integration macro for MSD Chemstation
Posted: Wed Sep 28, 2011 4:08 am
by pacerlaser
I was wondering if there is a macro or script out there that allows the possibility for choosing an R code to put on a chromatogram for a manually integrated peak. It is kinda annoying having to hand write R codes next to several compounds on a chromatogram printout. Ideally, I would like a list to pop up after you manually integrate a peak asking what R code to place on the final printout.
Re: R code manual integration macro for MSD Chemstation
Posted: Wed Sep 28, 2011 3:56 pm
by sepscientologist
What the heck is an R code? Are you writing code in the mathematical language "R"?
Posted: Thu Sep 29, 2011 2:38 am
by pacerlaser
Sorry I should have explained better. Whenever we perform a manual integration, we must indicate why the integration was performed by writing the letter R followed by a number, for example R38 would be peak area enhanced by software. I was wondering if there is a way to have a drop down list present a list of choices that will should up next the to the "m" on the chromatogram printout with the appropriate R code next to it so we don't have to hand write it anymore.
Posted: Mon Oct 03, 2011 5:30 pm
by pacerlaser
This is similar to what I'm looking for, http://www.abacusdb.com/mFlagMacros.aspx
