R code manual integration macro for MSD Chemstation
I was wondering if there is a macro or script out there that allows the possibility for choosing an R code to put on a chromatogram for a manually integrated peak. It is kinda annoying having to hand write R codes next to several compounds on a chromatogram printout. Ideally, I would like a list to pop up after you manually integrate a peak asking what R code to place on the final printout.
What the heck is an R code? Are you writing code in the mathematical language "R"?
Sorry I should have explained better. Whenever we perform a manual integration, we must indicate why the integration was performed by writing the letter R followed by a number, for example R38 would be peak area enhanced by software. I was wondering if there is a way to have a drop down list present a list of choices that will should up next the to the "m" on the chromatogram printout with the appropriate R code next to it so we don't have to hand write it anymore.
This is similar to what I'm looking for, http://www.abacusdb.com/mFlagMacros.aspx
In total there are 40 users online :: 0 registered, 0 hidden and 40 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 40 guests
