Autosampler and Headspace
Posted: Mon Sep 12, 2011 1:08 pm
by superkidz
We are currently making specifications of autosampler and headspace for GC 7890. Any recommendations? We plan to attach the GC to Waters Xevo QTof . GC and LC will be using one MS then. Im just concerned with the compatibility issues. Thanks
Re: Autosampler and Headspace
Posted: Tue Sep 13, 2011 12:40 am
by Karen01
What compatibility issues are you worried about?
The APGC ion source is totally separate from the ESI source. While you can control the 7890 from MassLynx I don't know if you can control the Agilent G1888 or 7697A headspace Sampler... Not a big deal IMO as it's easy enough to start a run from the HS sampler...
That said I know the Combi-PAL (which can do liquid or HS injections) is supported in MassLynx...
BTW what do you plan to use the APGC source with the XEVO for?
- Karen
