Galaxie Chromatography Data system
Posted: Thu Aug 18, 2011 12:32 pm
I would appriciate if somebody can help me with the constructing calibration curve for the CP-3800 Varian GC using the Galaxie Chromatography data system.
I have oppened the new sequence and entered the 5 levels of the standard I am using, click for the first one :Clear old points and than add levels for the other up to 5th level.
Also on the method in the lefet bottom screen under the calibration, enetered the date and the name of the new calibration curve, and new 5 levels with the calculated ammount of my standard. Everything is saved, Gc run all samples but when wanted to open the calibration curve I can not.
What can I do, or what I am missing, I knew we can do something through reprocessing but do not know the right way.
Thank you
Thank you
