Running LC/MS chemstation without the MS turned on
Hi Everyone
I have an ion trap and UV detector running on chemstation and want to run a method using only the UV with the MS detector turned off.
If I turn on chemstation with the ion trap turned off it displays an error and wont let me load do anything. Does anyone know a way to remove the MS from chemstation temporarily and just run a UV method?
Stephen
Not sure if this will work for your setup but worth a try: http://www.chem.agilent.com/en-US/Suppo ... 00213.aspx
Insanity: doing the same thing over and over again and expecting different results.
Albert Einstein, (attributed)
US (German-born) physicist (1879 - 1955)
Users browsing this forum: Google [Bot] and 12 guests
