extract and determine a Pharmaceuticals in oi
hii,
i am traying to extract and determine a Pharmaceuticals in oil, can you help me please???????
i want to determine:
Ampicillin,Carbamazepine,ciprofloxacin,Sulfadimethoxine,Tetracycline,17b-estradiol.
thank you
Hi!!!
You need to know properties of these medicines.
For example: Ampicillin has -NH2 and -COOH groups, badly soluble in water, stable in acidic solutions (data from wiki). In this case I would use aqueous solution with low pH to extract ampicillin from oil.
Also it would be usefull to add emulsifer to your oil then extracting
All I ever need to know I'm learned in cloning vats.
thank you
can you suggest what kind of seperation column can i use?
I guess C18 is an option, but I do not familiar with HPLC.
Also you can change retention time of analite with mobile phase.
You can change pH, % of organic in phase, and add some buffer or/and ion-pair solts.
hii
thank you, i will try
In total there are 48 users online :: 0 registered, 0 hidden and 48 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 48 guests
