Dionex Peaknet Help
Anyone that perhaps has seen this issue with peaknet.
I use OPTIMIZE , and after I name the peaks and they are properly identified etc, I go to Component Tables.
There I find that I only get round numbers for retention times
1.00, 2.00, 4.00 etc minutes. I cannot type in decimals for the minutes, nor are they automatically on the table as they should have been to begin with. I have that problem in different installations of Peaknet in different PCs and different OS.
Has anyone seen this before?
What version of PeakNet do you use and what operating system? Pls specify exactly. It can be an effect of decimal point charakter (. or ,) settings. Pls check the number format in the control panel of the operating system. Good luck.
Stefan Brand
Thermo Fisher Scientific
Problem solved according to your suggestion...
Thanks for the input.
