PeakNet Data Migration
Posted: Tue Jun 28, 2011 2:48 pm
by kambammadan
Hello Everyone,
We are working on our data migration process for our client-server upgrade project and we’ve run into a potential problem; it appears that we are unable to backup PeakNet data using the Chromeleon backup function. We’ve done a few backup tests and as far as we can tell Chromeleon ignores PeakNet data. Do you have any suggestions?
Madan
Re: PeakNet Data Migration
Posted: Tue Jun 28, 2011 5:44 pm
by unmgvar
what you need to do I think is to restore all the PeakNet data into your CM data source
then you can use the possibilities of archiving and storing provided by CM
Posted: Tue Jun 28, 2011 5:56 pm
by kambammadan
Chromelen 6.x can only backup and restore PeakNet 6.x data. All previous PeakNet version data e.g. 5.x require an import of the data from that installation. A read only function or backup utilities for PeakNet versions before 6 are not available. Note that versions before 6 are purely file based.
So still figuring out the issue..
