Pressure fluctuate proplem ??
Posted: Mon Jun 27, 2011 10:38 pm
Hi there ,
I am using this pumb
when i start my analysis the pubm read ( 26 mPa ) then it rise up to ( 30 mPa ) then reduce to ( 29 then 32 then 27 mPa ) .
I usually degas my mobile phase and my samples are just water with analyte .
Does this will effect my peak area ??how can i solve the problem
my column ( 250 mm * 4.6 mm ) , flow rate = 1.2 ml/min
