Vitamin A +C in multivitamin tablets&vit. C and B1 in cereal
Hey everyone, i am new here and i wanted to ask a few thing if you can help me out..!
I have a project where i have to determine in the lab Vitamin A(fat soluble vitamin) and C ( water soluble) in multivitamin tablets and Vitamin C and B1 (thiamine) in cereals... needs to be with a C18 column and UV detector...
and i was wonderng if you have in mind any info or journals i can look too, cause i've haven't found much that include both sample prep (extraction mostly) and the following the HPLC parameter required!
thanks a lot! :)
thanks a lot! :)
Hi
This question solved long ago. See sea literature. 8)
PS
Ascorbic acid slightly oxidizaid . Don't Fe 2+, Fe3+ , Cu2+ iones ( red-ox catalist) . For its deactivated use EDTA-Na.
because i am new to a lot of these, can you be more specific on what you mean by sea literature pls?!
thanks! :))
thanks! :))
8) 8) 8)
Well
http://en.wikipedia.org/wiki/Ascorbic_acid
http://en.wikipedia.org/wiki/Retinol
http://en.wikipedia.org/wiki/Thiamine
http://en.wikipedia.org/wiki/Cholecalciferol
http://en.wikipedia.org/wiki/Lactose
http://en.wikipedia.org/wiki/Starch
http://en.wikipedia.org/wiki/Polyvinylpyrrolidone
Here, approximately 15,000 direct links, you'll fit about 800.
http://www.google.ru/webhp?hl=ru&tab=ww ... Bby%2BHPLC
http://www.google.ru/search?hl=ru&newwi ... 09ef7&bs=1
http://www.google.ru/search?hl=ru&newwi ... 1b04809ef7
And this is for you. True Russian. But the exclusive
http://www.anchem.ru/forum/read.asp?id=9264
http://www.econova.ru/applications/publ ... sis_23.pdf
I hope Professor Baram (creator first UPLS ( Novosibirsk "Orlenok"-"MiLiChrome-1" (1968)) for me not to be offended :D
As we say in the village - "and-forth with a song" . Since the "rescue of drowning, the handiwork of drowning. "(с)
When you come to a definite and reasonable opinion, then we are happy to discuss your ideas.
