Varian CP-4900 PRO Micro GC
Posted: Fri Mar 25, 2011 3:21 am
by Wajid
Hello Everybody....Specially Peter
With the subjected GC I am using PROstation software. I set up a method and application, calibrate it with calib blend and run analysis on it...all fine. I develop another method and application calibrate it and run analysis on it...all fine.
Now I load the first method and application and run analysis ....results abnormal. I find that it has Response factors of second method?????
I have samples of variable concentrations and so the calib blends are but how can I retain different calibrations?
Thanks in Advance
