leak in mass spec
Posted: Mon Mar 07, 2005 10:37 am
by doctorante
Sorry to ask again, but i am still dealing with this machine (HP 5971/GC 5890). Now, i can obtain more or less a proper signal (water and air < 5% of peak 69), but as soon as i increase the temperature of the oven I observe an increase in the air and water levels. If I decrease the temperature the levels are OK again, after a while. Could i have a pore in the column which is widening with the increase of temperature?
Any help is welcome
Jose
Posted: Mon Mar 07, 2005 1:50 pm
by Consumer Products Guy
Tighten the fittings while the oven is hotter, there can be expansion/contraction issues. Focus on the MSD interface, the 1/2 nut holding the gold seal and its washer in place, the weldment retainer nut, and septum nut. The issue is in the GC, not the MSD, you've already isolated that issue.
thanks!
Posted: Tue Mar 08, 2005 11:44 am
by doctorante
I will try replacing ferrules and setting another column... we'll see what can i obtain.
Many thanks!
Posted: Tue Mar 15, 2005 2:52 pm
by Rick
Maybe gas trap or gas cylinder is contaminate.When oven temp increase, water trap on column head is liberate.Bypass gas trap...what is the result???
Good luck!
