Acquity PDA Baseline Signal Bottoming Out (negative)
Posted: Thu Nov 04, 2010 4:40 pm
Hi there,
I've had this issue before, and cannot remember how to fix it. Basically the detector signal goes negative and "flat-lines", and then doesn't seem to be a way to "balance" or rectify. The signal is just staying flat at -0.0653 AU!
Can anyone offer any suggestions.
PS. Not running anything unusual: big standard water, AcN +0.0%% TFA in both lines, gradients - or trying to
