Electrical connection between ATD Turbomatrix and HP5890
Posted: Wed Sep 29, 2010 9:34 am
Which is the right electrical connection between a thermal desorber ATD Turbomatrix and a GC HP5890?
Our Gc is followed by a MS Trio.
The pins of the ATD Input/Output (I/O) port are:
14 ground
13 ground
12 ground
11 Start in
10 Stop in
9 Ready in
8 Fail Out Normally Open
7 Fail Out Normally Open
6 Start normally open (Start out - Inject)
5 Start normally open (Start out - Inject)
4 Ready normally open (not ready)
3 Ready normally open (not ready)
2 Ready normally open (ready out)
Pin # 1 Ready normally open (ready out)
and the pins of the remote port 6 of HP 5890 are:
6.12 REMOTE READY INPUT
6.11 GND
6.10 START OUTPUT (same as pins 7 & 8 above)
6.9 READY OUTPUT (connects with 5 @ ready)
6.8 START OUTPUT (100ms to signal start of run)
6.7 START OUTPUT (contact closure; pulsed closure for)
6.6 READY OUTPUT (disconnects for 5 @ ready)
6.5 READY OUTPUT (common for 6 & 9)
6.4 GND
6.3 REMOTE CONFIGURATION INPUT
6.2 GND
6.1 REMOTE START INPUT
According to the manual of ATD Turbomatrix the pins which are used for the electrical connection between Turbomatrix and HP 5890 are 5,6,9,12.
Thank you.
Christiana
14 ground
13 ground
12 ground
11 Start in
10 Stop in
9 Ready in
6.11 GND
6.4 GND
6.2 GND
Thank you.
Christiana
