Robustness testing - wavelength variation
Posted: Fri Jul 30, 2010 9:08 pm
Hi all,
In the valiadation of a stability-indicating assay and impurities methods,
what acceptance criteria do you all normally apply to robustness results? Also, do you normally evaluate wavelength as part of robustness testing, and if so, what range do you usually evaluate (e.g., +/- 2 nm)?
Thanks!
Thanks!
