Optimal peak height for IC quantitation
Posted: Wed Jul 28, 2010 5:21 pm
Hi, I'm using an ICS-2000 running Chromeleon 6.8.
I was experimenting with the signal-noise measurements when I thought of a question:
For quantitation purposes, what it the maximum/optimal peak height you want to aim for? Too high and the peak could flatten at the apex; too low and you'll have to high of a signal to noise ratio.
Thanks!
Thanks!
