Nano-scale alternative of ZIC-pHILIC
Posted: Tue Jul 27, 2010 4:34 am
by plusik
We are currently running an HPLC-MS system, with a ZIC-pHILIC column installed. We use acetonitrile (A) and 10mM ammonium carbonate pH 9.3 (B) as a mobile phase and 100ul/min flow rate.
We would like to switch to nano-scale UPLC setup in order to increase the sensitivity of detection. Can anyone recommend a good alternative for the ZIC-pHILIC column for nano-scale flow rate?
Thank you!
Tomas
Posted: Wed Aug 18, 2010 12:26 pm
by Bintang
We are happy you are using our column.
If you e-mail us at
support@mercksequant.com
We will try to help you.
