who have shimadzu gc-ms?
is here any member have a shimadzu gc-ms?
GCMS 2010 (GC2010+QP2010). EI + PCI + NCI.
Question(s)?
Roberto Barcarolo, Italy
Question(s)?
I have shimadzu library for benzodiazepines and would like to convert it into a format that can be read by NIST MS search.
I am sorry but I use only Nist libray. If you have other question about GCMS instrument I am here.
Regards.
Robertino Barcarolo
Regards.
Robertino Barcarolo
- CE Instruments
You can try looking for Masstransit software, it should do what you want ?
http://www.sisweb.com/software/masstransit.htm
I used GCMS shimadzu QP2010Plus. I had question. If i used splitless injection mode do i need to change split ratio?
you can choose split ratio -1 while using splitless injection method. it means that the instrument will set the split ratio automatically.
To convert Shimadzu libraries to msp format, and from there to NIST format, you can use Openchrom and lib2nist !
In total there are 26 users online :: 2 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 24 guests
