we are having problems with the peak shape of our analyte in ESI negative mode. The technicians of the supplier of the MS/MS don`t have any remaining idea.
We analyzed nucleotides and used 50 mM NH4HCO3 pH 10 (adjusted with NH4OH (p.a.)). Eluent B is MeCN(MS-grade)/acetone (for contaminants). After a few weeks we became the problem, that the peaks of the nucleotides became a zigzag-line. Other parameters measured in negative mode now show a similar peak shape.
We run a standard with a second MS/MS, not used for the nucleotides before, but had the same peak shape.
So we changed the eluent to NH4Ac (without NH4OH) und MeCN (MS-grade) but nothing changed.
We don't have any problems in positive mode.
Does anybody have an idea about this problem?
Thanks!!
