Recently I got hold of a Tekmar 3100. It does not seem to be talking to the 5971/5890 system using the same setup as I used with the Tekmar 3000.
These two P&T concentrators look nearly identical inside both as to gas lines, valves, and circuit boards. Any thoughts why the 3100 should not work?
Solved: Yes they do indeed work without any problems.
