Custom Fields with two API's
Posted: Mon Aug 18, 2025 8:02 pm
I am running an analysis that has two API's that need to be quantified (for both Assay and Impurities) and i need to use two different processing methods (one for the standard and one for the sample. The sample set is set up to injection all impurities standards (both working and check) and then all assay (both working and check) then the samples. The assay and impurities are evaluated in the same preparation using the different standard concentrations. Because I have the impurities analysis I need to create a separate processing method to include all impurities and also quantify them. Is there a way to process and set up custom fields to calibrate with one PM and then quantitate with another? if so how do i set it up.
