The Problem: Compressor Dependency & Storage Hazards
In our recent study tracking PFAS in urban watersheds, we struggled with:
Pressure instability: External compressors caused ±15% flow fluctuations, distorting retention times during 24-hour runs.
Space constraints: Storing multiple H₂ cylinders in our BSL-2 lab violated safety protocols and consumed 30% of our bench space.
Contamination risks: Cylinder-derived hydrogen showed trace CO₂ (2–3 ppm), interfering with our electron capture detector’s baseline.
Solution: Compressor-Free High-Pressure Operation
The LX-Series addressed these issues through:
Integrated Pressure Boosting
70 bar output via multi-stage electrochemical compression (no mechanical compressor).
<1% pressure fluctuation during our 72-hour continuous PFAS analysis (vs. 8–12% with cylinder/compressor setups).
On-Site Synthesis = Zero Storage
0.5 L/min on-demand production matched our GC-MS’s carrier and detector gas needs.
Removed 4 high-pressure cylinders from our 25 m² lab, freeing space for additional instrumentation.
Case Study: PFAS Quantification in Complex Matrices
Objective: Detect 28 PFAS compounds in landfill leachate (LOQ ≤ 0.1 ppb).
Previous Setup:
Hydrogen cylinders (99.995%) + external compressor.
Baseline noise: 12–15 pA (attributed to compressor oil vapor carryover).
Retention time drift: ±0.3 min over 12 hours.
Implementation:
Direct connection to Agilent 8890 GC/5977B MSD.
Results:
Baseline noise reduction: 4–5 pA (stable over 48 hours).
Retention time RSD: Improved from 1.8% to 0.4%.
PFAS recovery rates: 92–105% (vs. 85–97% previously).
Researcher Feedback:
“The compressor-free design cut our prep time by 40 minutes per run. Not worrying about cylinder swaps let us focus on optimizing SPE protocols.”
— Dr. Elena Voss, Lead Environmental Chemist
Data integrity: Stable pressure enables reproducible retention indices for non-target screening.
Scalability: Modular design supports simultaneous GC-MS/TQMS operation without pressure drop.
Discussion Points:
How have hydrogen supply limitations impacted your method validation processes?
For those in confined labs: What safety trade-offs have you faced with gas storage?
Interested in technical validation data or our full PFAS study? I’m happy to share details via DM or email.
Ron.N
Senior Research Associate | Environmental Analytical Chemistry Group
Note: Instrument compatibility varies;
