retention order for VOC mixture?
Posted: Fri Oct 04, 2024 1:30 pm
by therdem
I need retention order for volatile organic carbon mix for GC-FID analysis. Or can you suggest me some components so that I can identify location easily. I have some mixtures from different companies?
Can you share some chromotogram or retention order or any other suggestion.
Benzene, Bromobenzene, Bromochloromethane, Bromodichloromethane, Bromoform, Bromomethane, sec-Butyl benzene, tert-Butyl benzene, n-Butyl benzene, Carbon disulfide, Carbon tetrachloride, Chlorobenzene, Chloroethane, Chloroform, Chloromethane, 2-Chlorotoluene, 4-Chlorotoluene, Dibromochloromethane, 1,2-Dibromo-3-chloropropane, 1,2-Dibromoethane, Dibromomethane, 1,2-Dichlorobenzene, 1,3-Dichlorobenzene, 1,4-Dichlorobenzene, Dichlorodifluoromethane, 1,1-Dichloroethane, 1,2-Dichloroethane, 1,1-Dichloroethene, trans-1,2-Dichloroethene, cis-1,2-Dichloroethene, 1,2-Dichloropropane, 1,3-Dichloropropane, 2,2-Dichloropropane, 1,1-Dichloropropene, trans-1,3-Dichloropropene, cis-1,3-Dichloropropene, Ethyl benzene, Hexachlorobutadiene, Hexachloroethane, Isopropylbenzene, p-Isopropyl toluene, Methyl tert-butyl ether (MTBE), 4-Methyl-2-pentanone (MIBK), Methylene chloride, Naphthalene, Nitrobenzene, n-Propylbenzene, Styrene, 1,1,1,2-Tetrachloroethane, 1,1,2,2-Tetrachloroethane, Tetrachloroethene, Toluene, 1,2,3-Trichlorobenzene, 1,2,4-Trichlorobenzene, 1,1,1-Trichloroethane, 1,1,2-Trichloroethane, Trichloroethene, Trichlorofluoromethane, 1,2,3-Trichloropropane, 1,2,4-Trimethylbenzene, 1,3,5-Trimethylbenzene, Vinyl chloride, p-Xylene, o-Xylene, m-Xylene
Re: retention order for VOC mixture?
Posted: Tue Oct 08, 2024 7:32 pm
by 70 eV
Why are you trying to run a TO-15/524/8260 mix on a FID? Buy a MS. If you're dedicated to being a cheap SOB throw your column and analytes into restek's EZchrom, but you should buy individual standards of each compound for analog detectors to establish RT.
Posted: Mon Oct 21, 2024 10:47 pm
by LALman
RESTEK usually has chromatograms for the VOC's on different columns. You would need two columns for positive identification of peaks. I agree with the last poster. You need a more specific detector. GC-MS would be the best.
Posted: Wed Nov 27, 2024 7:08 am
by therdem
Thanks for the reply. I have just started. Company have ms and fid. however, they have only one column. when column passed ms to fid, I have to cut about 30 cm. Therefore I cant use old calibration on fid, plus I don't trust old calibration retention order since ther choose very far away locations for p and m xylene. and ms works for PAH almost non-stop.
Thanks anyway.
Posted: Wed Nov 27, 2024 2:19 pm
by DR
Right... let either the $80,000 GC or the $300,000 GCMS sit for want of a $600 column.
You don't need a new column nearly as much as you need new management (and an additional GCMS).
Posted: Wed Dec 04, 2024 8:05 pm
by natali.g17
https://docs.accustandard.com/docshare/ ... R2-10X.pdf This chromatogram might be helpful, but I'd also highly recommend using GC-MS instead of GC-FID.
