Hi Ddlidd,
YMC has some options for the analysis of phosphatidylcholine and other phospholipids with C18 columns. please keep in mind that you may want to have inert/biocompatible hardwares for this, so make sure you have both columns and HPLC instruments that do not have wettable parts made of stainless steel. Organophosphorous compounds may be very "sticky" to the steen surface due to lewis acid-lewis base kind of intermolecular interactions!
YMC has some work that has been published with Triart Accura series. The Triart series has some very pure and well endcapped silica and the Accura hardware is made of ss with the inner side covered with a thin ceramic layer that eliminates any possible secondary intermolecular interaction between molecule and ss. Please find some examles below:
https://www.ymc.co.jp/uploads/1220/UHPL ... umn_v1.pdf
https://ymc.eu/files/imported/publicati ... art-C8.pdf
