For clarification, our company just started using Empower (previously TurboChrom) before empower we would use an excel sheet and manually type in each impurity that is above 0.05% to calculate %area of active and total %area of all impurities. With Empower the %area of each individual impurity is being calculated using the impurities that are below LOQ (0.05%) causing the total impurities to be slightly different than that of what we've historically done.
